RCA lenghts
Audio, video, navigation, radar detectors and more. Also for alarms, security systems, kill switches, and other immobilization techniques.
RCA lenghts
Postby Gost_Dog » Fri Mar 03, 2017 11:15 am
Hey guys!
I dont have access to my car right now and need your help.
Im wondering what lenghts of rca cable to you use in your setup?
im trying to go from my headunit to the cargo storage box.
Thanks in advance!!!
Gost_Dog
Re: RCA lenghts
Postby Theboy » Fri Mar 03, 2017 2:13 pm
Carwidth+Y+Z+P
Y= Height from floor
Z= Center to center front rear wheel * .66
P= Length of plugs (they wont bend)
Therefore a CRX
57.3"+36"+(90.6" * .66)+3"=156.096"
Theboy
Re: RCA lenghts
Postby umop3plsdn3dlus » Sat Mar 04, 2017 12:24 am
Average rca length you will find in stores is 17ft which is PLENTY of cabling for a crx
Dustin - Central Texas
umop3plsdn3dlus
Re: RCA lenghts
Postby Gost_Dog » Sun Mar 19, 2017 8:06 pm
thanks guys!!!!
Gost_Dog
Re: RCA lenghts
Postby Mista Bone » Mon Mar 20, 2017 2:27 am
When I did a pro installs, I'd purchase 300 ft of RCA shielded cable and enough ends + 10% to cover the install.
Re: RCA lenghts
Postby cboutilier » Wed Mar 22, 2017 6:50 pm
Depends on where you plan to route it. Regardless 6 to 10 feet will be more than enough
Corksil wrote:Build it right, build it once.
1991 TGP CRX Si: b18a1, spec-d, tein, konig
1985 Prelude: stock A18 dual carb
1993 MR Civic CX: b16a2, skunk2, autometer, magnaflow, etc. (traded for rex)
cboutilier
Re: RCA lenghts
Postby Mista Bone » Wed Mar 22, 2017 11:46 pm
six feet might not be enough (one arm span) but 10ft/3m will be plenty if going right down the center console.
I generally did this as I hated the wire "bumps" you'd find with your shoes. Sure you have to pull a seat to do this, but that is easy.
Re: RCA lenghts
Postby cboutilier » Thu Mar 23, 2017 6:33 am
I'll probably take my RCA out this weekend as I don't run gear anymore. I'll let you know how long they were.
cboutilier
Return to Car Audio, Gadgets and Security
