How To: Turn your bumper lights into running lights
Swaps, bolt-ons, tuning, turbo/super-charging, nitrous, suspension upgrades, etc.
Postby jfrolang » Mon Aug 25, 2008 11:25 pm
I've posted this a few times when it comes up, I guess it's time to make it more permanent.
If you wanted to turn the bumper light into only a running light, you would tap into the hot wire of the front bulb on the corner lights and run them down to the bumper lights, replacing the factory wiring there. However, I don't recommend this, since people facing you head on won't see your signals, and it's probably not legal.
The way that I did it, the bumper lights will be on when the parking lights are on, and will still function as turn signals.
Basically, you're gonna swap out the factory 1156 bumper light bulbs for 1157 dual-filament bulbs. Get the corner light bulb sockets from a 92-95 Civic, either from the junkyard or from a Honda dealer. These are designed for 1157 bulbs and will hook right up to the CRX bumper light housings, at least for 90/91 cars.
So once you've got the new sockets and a fresh pair of 1157 bulbs from the parts store, you can put them in. There are 3 wires on the 1157 sockets, and you only have two wires on the stock bumper lights. Ground goes to ground, and you're going to tap into the front bulb of the corner socket for the third wire.
An 1157 bulb, for those uninformed, has a "bright" and a "dim" side. The factory bumper light hot wire goes to the bright side of the 1157. You just have to twist the wires together temporary like to see which is which, before finalizing the connections. The wire you pulled down from the corner lights will go to the dim side of the 1157.
In this way the turn signal circuit is unchanged, and will still be visible over the less bright running light circuit you've added.
jfrolang
Site Admin
Postby tex00000 » Sun Nov 09, 2008 9:18 pm
wont this cause the turn signal lights to spaz out as if their was a burnt out bulb?
tex00000
Postby jfrolang » Sun Nov 09, 2008 9:21 pm
No, the stock turn signal circuit is unchanged. You're adding an extension to the running lights circuit and using a dual-filament bulb in the bumper lights. There is no crossover.
jfrolang
Site Admin
Postby tex00000 » Sun Nov 09, 2008 9:24 pm
sweet post up isnt there a way you could change it so the front bulb acted as the blinker instead of the back one that way it was more visible for oncoming vehicles?
tex00000
Postby jfrolang » Sun Nov 09, 2008 11:05 pm
Your bumper lights still blink and are forward facing.
jfrolang
Site Admin
Postby tex00000 » Mon Nov 10, 2008 2:24 pm
alright maybe i miss read that thanks
tex00000
Postby parrotcrx » Sat Jan 31, 2009 5:54 pm
i just did this today on my car and it took me no longer than 30mins and it looks really nice thanks :D
90 CRX HF
D15B8
with a gs-r stroker in progress:)
parrotcrx
Postby X and V » Wed Feb 25, 2009 4:52 am
yeah you can also do this to the rear turn signals! Trips people out
1990 CR-X Si
2007 CR-V EX-L
X and V
Re: How To: Turn your bumper lights into running lights
Postby hondahustle » Sat Mar 07, 2009 8:53 pm
Man that looks sick...wonder if it'll work on the hatch? I bought the sockets for the EG bulbs but they don't seem to fit. :(
hondahustle
Postby thenightmare » Sun Mar 08, 2009 6:00 pm
Oh man, thats such a cool mod. I will definetly try this, thanks.
thenightmare
blinker
Postby Brujo13 » Tue Mar 31, 2009 12:35 am
so will this leave the bumper lights on when the head light are on? or just when the parking lights are on?
"BoB" Rio Red 88 Si - Stock
Brujo13
Re: blinker
Postby jfrolang » Tue Mar 31, 2009 1:21 am
Brujo13 wrote:so will this leave the bumper lights on when the head light are on? or just when the parking lights are on?
Both.
jfrolang
Site Admin
Re: blinker
Postby Brujo13 » Tue Mar 31, 2009 2:58 am
Both.
sweet. junk yard time tomorrow
i need to make a list of all the stuff i need to search for and get
Brujo13
Postby Baker » Tue Mar 31, 2009 12:58 pm
It's funny that though is not stock, looking at some of the Honda promo/brochure pics, they have the bumper lights wired like this.
http://photo.netcarshow.com/Honda-Civic_CRX_Si_1990_photo_01.jpg
http://photo.netcarshow.com/Honda-Civic_CRX_Si_1990_photo_02.jpg
Moderator
Postby rexy » Wed Apr 01, 2009 2:49 pm
nice find MR, baker,,, dang those cars are sweet, but yes I also think I'll do this, i have wondered why this is not a stock set up before just never thought to do it, but it does look nice... nice write up and thanks...
rexy
Postby rexy » Thu Apr 09, 2009 2:42 pm
Okay, Question.... I don't have any 92' civics laying around to pull parts off of so I called my trusty local honda dealer, now he has the socket for the 92'civic but it has no wire leads coming from it so I assume the cars harness has a plug that plugs into the socket... if this be tha case do the plugs from the crx the same as the plugs from the 92'?????
rexy
Postby MltsAccord » Mon May 04, 2009 3:14 pm
j/w if u just splice into the turn signal and run it to the bumper lights, keeping the same bulbs wont it stay on, and then blink when need be?
MltsAccord
Postby jfrolang » Mon May 04, 2009 7:02 pm
rexy wrote:if this be the case do the plugs from the crx fit the same as the plugs from the 92'?
No, you're talking about 2-pin and 3-pin plugs, they don't interchange. Just go to your local junkyard, I'm having a hard time believing that you have no EG Civics in your local yards. Honda literally sold Millions of Civics in the 90s.
MltsAccord wrote:j/w if u just splice into the turn signal and run it to the bumper lights, keeping the same bulbs wont it stay on, and then blink when need be?
No, in that case they would only stay on, as there would be constant power. You're also dealing with a "cross the streams" situation with something like that, sending electricity back down the wires in the wrong direction, potentially damaging relays or switches.
jfrolang
Site Admin
Postby rexy » Mon May 04, 2009 8:21 pm
believe or not not I don't ,, the only yard I have in this area is crush and go,,, nothing gets sold out of it,, but thanks
wiring is not strong suit, I'll look over it again and will get -r - done...
rexy
Postby MltsAccord » Mon May 04, 2009 9:08 pm
ahh yea makes sense
MltsAccord
Postby mwile2k5 » Sat May 23, 2009 12:04 am
Ok I have been messing with this for hours, and Ive somehow got it all screwed up. I dont know if its because I spliced my bulb sockets wires and just soldered the wires into the sockets or what. I did this because I had no wire connector to connect the bulbs so I just cut the end of the orginal 2 wire socket, soldered those 2 wires into the new 3 wired socket, then I tapped into the hot wire from the running corner lights. Now here is my problem:
WHEN LIGHTS ARE TURNED ON:
All front lights work including, left and right corners, and left and right bumpers
Right rear signal light is on
Left rear signal is NOT on
On in dash cluster, the Right signal is LIGHTLY lit?
LIGHTS ON, SIGNALS ON:
Left and right, signals all flash fast like bulbs are out or going out
Right corner signal is NOT working
Left corner signal is NOT working
LIGHTS OFF, SIGNALS ON:
Right side all works FINE!
Left side all works BUT BLINKS FAST?
Since I have replaced all corner small bulbs. I do not know what is going on, I especially dont know why my right turn signal on the cluster lights up very dim when I turn the lights on? I have had some problems with my left rear brake light before, sometimes it works sometimes it doesnt. Its like sometimes I just have to finaggle with it to get it to work. Seems like theres a short somewhere but I dont know where? Any help or advice would be GREATLY appreciated!! Thanks!
mwile2k5
Postby rexy » Wed Jun 03, 2009 8:51 pm
mwile2k5 wrote:Ok I have been messing with this for hours, and Ive somehow got it all screwed up. I dont know if its because I spliced my bulb sockets wires and just soldered the wires into the sockets or what. I did this because I had no wire connector to connect the bulbs so I just cut the end of the orginal 2 wire socket, soldered those 2 wires into the new 3 wired socket, then I tapped into the hot wire from the running corner lights. Now here is my problem:
WOW... you need to start over or maybe just quit,, you really need to get the 92-95 sockets and the plug that goes with it ,, I finally found a donar car and now that I have the parts in hand and see what it is this will be a cake job but nice ,,, thanks for a cool write up,, I'll post pics this weekend when I get mine done,,,
rexy
Postby Baker » Thu Jun 04, 2009 12:16 pm
How?? It literally took me 30 mins to do.
I cut the bulb sockets with harness and about 6' of wire from a 96-00 Civic, spliced it in and BANG, done.
Moderator
Postby rexy » Fri Jun 05, 2009 8:21 pm
I got mine done I'd love to post pictures but it say the img is off ,,, but it works great,,, the wires are even basically the same color from 95 hatch to 91 crx grn, red ,blk, can't get any easier than that... thanks for the write up ,,,
rexy
Postby CiRKiS89ReX » Fri Aug 28, 2009 6:26 am
This looks very legit, i like it!I want to do this when i get my rex back :) Quick question to anyone who has done this, do your signals flash fast or slow with this mod i would like them to flash slow stock im guessing they would right?THANKS
CiRKiS89ReX
Return to Modification Garage
Users browsing this forum: helobeast, stevechvz and 2 guests
