ECU Chipping and Tech
Swaps, bolt-ons, tuning, turbo/super-charging, nitrous, suspension upgrades, etc.
Postby downest » Thu Jun 28, 2007 2:19 pm
Ok, I got a bunch of pics loaded and it's time we have some resources on ECU chipping and OBD conversions.
First off, OBD0 stuff. TurboEdit (now Open TurboEdit) has come a long way, supports a lot more than it did years ago, and is still free. This is the cheapest route to go for most CRXers, since it's OBD0 based and the chipping required is minimal.
The ECUs you want to have for OBD0 stuff are:
PG7 (88-89 Integra D16A1)
PM6 (EF Civic/CRX Si D16A6)
PM7 (89-91 Civic Si ZC)
PR5 (90-91 Integra ZXi)
PS9 (EF Civic EX, usually AT)
PK2 (88-91 Prelude B20A)
PM8 (CRX HF, D15B6)
PR4 (90-91 Integra B18A, there are OBD1 PR4 as well)
There are some others, but those are the ones you're likely to encounter.
Chipping OBD0 is pretty simple, it requires at the minimum a chip, but preferably a socket and a ZIF socket to allow for more switching the chip, as well as a header for datalogging. I usually get all my chipping parts from Moates. I'll use the PM6 as an example, because it's very common, especially for CRX owners.
The year of the ECU is usually stamped in ink on the side, to the left of the label. Here are three PM6 ECUs, two with stamps:
The picture is kind of crappy, but you can see the middle one has no ink on it. The boxes outline the label and model of the ECU, the middle three numbers on all of these say "PM6". Generally, you want a "PM6-A09" for chipping. As far as I know, all 1988 PM6 are not easily chippable. Yes, it can be done, but IMO it's not worth it, considering how easy and cheap they are to get. Some 1989 ECUs are chippable and some aren't, you can look for the "A09" stamp, but to be sure, you have to pop it open.
Here are two PM6s. This one is non-chippable, the one labeled '89 from the picture above:
This one is chippable, the un-stamped PM6-A09 in the pic. The boxes outline the external EPROM (which you replace with a chip) and the place to add the datalogging header (CN2).
Chipping a PM6 is pretty simple. You just remove the EPROM and add in a socket and ZIF socket. Depending on the socket and ZIF socket you use, you may need to slightly bend some components for clearance, but there is generally plenty of room. Optionally, you can install the datalogging header to CN2.
Here's a chipped PM6, using a low-profile ZIF from Moates:
That's about it for chipping OBD0 stuff, though there are variations. The ideal ECU to get IMHO if you're staying with OBD0 is the PS9 AT, since you can use the automatic's lockup solenoid output for VTEC, it can pretty much do anything. This may be the same for auto PR4s, I haven't done it.
Now on to OBD1. OBD1 ECUs have a LOT more aftermarket support, from free programs like Crome Free and ECU control to mid-range things like Crome Pro, and up to Hondata and Neptune. The most common OBD1 ECUs you'll see are:
P28 (92-95 Civic EX/Si Del Sol Si D16Z6)
P06 (92-95 Civic Dx D15B7)
P30 (Del Sol VTEC OBD1 B16A2)
P61 (DA Integra GSR 92-93 B17A)
P72 (DC Integra GSR B18C1 OBD1)
There are, of course, MANY others. Generally the most desirable OBD1 ECUs are P28s and P72s. They both can run any engine, but the P72 has the advantage of supporting knock sensors and IABs (which are used in the B18C1 and H22). Other non-VTEC OBD1 ECUs can be chipped and modified to support VTEC and enable/disable automatic transmission.
All OBD1 ECUs are chippable, so you don't have to worry about looking for a date stamp. They have the same kinds of labels on the sides that the OBD0 ECUs have, again with the middle three characters giving the model (ie, "-P28-").
There is more involved in chipping an OBD1 ECU than an OBD0 ECU. In addition to adding a socket and chip, and additional chip must be added, as well as two capacitors, a resistor, and a jumper. For datalogging, the header must be added to CN2 and a jumper must be cut. Moates conveniently sells kits with the parts needed to chip an OBD1 ECU, as well as a USB serial converter for easy datalogging.
This picture is a chipped P28. The boxes highlight the areas where components need to be added (on the right), the datalogging header (lowest on the right), and the jumper J12 that needs to be cut in order to datalog.
This is a P72, also chipped. Notice the extra board taking up the upper-right quarter of the ECU, this is the knock board.
*note this case has been modded, it normally looks just like a P28 when closed (other than the label)
Conveniently, OBD1 boards have a dotted outline around the EPROM area, and you just have to add components to all the blank spots. The smaller ones are labeled with Js, Rs, and Cs for jumper, resistor, and capacitor, so once you have the parts it's pretty simple.
Finally, OBD2a stuff. This crap is useless, but here's a pic of a P2P (D16Y8) ECU opened up:
For any of the chipping stuff, all you do is desolder the board, either removing components like with OBD0 boards, or opening the blank holes with the OBD0 CN2 or any of the OBD1 stuff. I find the easiest way to do it is use a desoldering braid and wick it all off, then remove the component, or install the new one.
If anyone wants me to add more, I will, and eventually put it up as a how-to or something. I'll add it to the FAQ for now. Any specific questions?
Tom Downes
'91 CRX Si
'90 CRX HF (adopted)
Wicked Innovation New England's only AuthorizedNepTuner/Dealer
downest
Wicked Awesome.
Postby mattminerDOTcom » Thu Jun 28, 2007 2:51 pm
where did you get all those sweet ecus?
-M@
just livin' here in the us, trying to live the tuner lifestyle. real deal here man, all overnighted from japan
mattminerDOTcom
Wicked Mod
Postby BIG_T » Fri Jun 29, 2007 10:42 pm
its funny how turboedit has came along way bc i know the guy that started and runs it :wink:
-1995 240sx SOLD
-1990 240sx SOLD
-1991 CRX Si ls swap with goodies DD
BIG_T
Postby daveb91 » Sat Jun 30, 2007 1:45 am
BIG_T wrote:its funny how turboedit has came along way bc i know the guy that started and runs it :wink:
Blundar??
I also wanted to add xenocron has helped me tremendously in parts and advice.
daveb91
Postby zrickety » Sun Jan 11, 2009 2:39 pm
can we fix the pics?
edit: thanks downest!
91 CRX Si B16(XSi)
viewtopic.php?f=26&t=32702
zrickety
Postby downest » Sun Jan 11, 2009 4:29 pm
Weird, thought I had! Give me a sec, I got them all set up on my server (they used to be on the Panducky server).
Tom Downes
'91 CRX Si
downest
Wicked Awesome.
Postby v8huntncrx » Sun Jan 11, 2009 6:35 pm
So are these the two main components that you used to chip the pm6?
CN2 Latching Header
S4 Aries 28-pin Low-Profile ZIF
89 dx (non vtec mini me. Haha)
v8huntncrx
Postby downest » Sun Jan 11, 2009 7:17 pm
Yes. I have some more detailed pics I can post if you need them.
Tom Downes
'91 CRX Si
downest
Wicked Awesome.
Postby Gophat » Sat Jan 24, 2009 10:10 am
What editors do you use to change the ecu around?
- Chris
'88 CRX DX MPFI Ready (No Motor)
'86 Toyota Corolla SR5 Coupe
Gophat
Postby crexmonster » Sat Jan 24, 2009 10:51 am
i am on a chipped p28 on my gsr tuned with crome pro... I LOVE IT!
crexmonster
Postby Gophat » Sat Jan 24, 2009 10:59 am
What's free..? I have turboedit right now, anything else better?
- Chris
Gophat
Postby Call Me SIR » Sat Jan 24, 2009 12:16 pm
Gophat wrote:What's free..? I have turboedit right now, anything else better?
Well what programs you can use all depends on what ecu you are tuning. TE will do most all of your obd0 non-vtec ecu's. For obd0 VTEC ecu's I prefer BRE, specifically PR3 (PW0 isn't street tunable). If you go obd1 Crome Free would be my choice (I bought Crome Pro, more features).
If you are really wanting to street/dyno tune, go obd1. My self and other members will agree that you can do all the basemapping you want on obd0, but tuning obd0 sucks.
Join PGMFI.org and you will have access to all of the free tuning programs available.
"Enjoy the finer things in life."
Call Me SIR
Postby Gophat » Sat Jan 24, 2009 3:36 pm
Oh definitely, I have a P28 OBD1. I am currently running a d16z6. I want to figure this stuff out so I can run it on my H. I rather ruin a z6 than that motor.
- Chris
Gophat
Postby bradterd » Sun Jan 25, 2009 1:14 am
Can you run a stock b16 map on a pm6 with either TE or BRE? Reason being, I have a chipped pm6 but my pwo isn't.
90 crx si Silverstone Metallic
B16a/GSR tranny with 50shot...
while I build the d16.
bradterd
Postby ChokolAwt » Sun Jan 25, 2009 2:24 am
if your b16 is obd0 then ya...
there is a way to use vtec with TE, but im not so sure about it...
SupaHondaCRX wrote:do you want your car to be [crud] balls fast or not?
vouch for: yamaha6611, mattminerdotcom, blackbirdpilot, Reckone
ChokolAwt
Postby daveb91 » Sun Jan 25, 2009 9:43 am
Vtec works with TE you use the A/C ECU output to activate it. That great if you dont have AC, by now maybe they are using another unused output...
daveb91
Re: ECU Chipping and Tech
Postby jtkc » Tue Sep 29, 2009 1:40 am
someone on here has a chipped PM6 for 50 bucks. If purchased? is it as simple as just switching the ECU's? I own an 88 si stock non chipped or would it be better to send mine to miner or someone to have it socketed and chipped?
jtkc
Re:
Postby Hybrid88 » Wed Sep 30, 2009 10:55 am
i beg to differ, i have run bre with a pwo and a pr3 for some time. i found it and turboedit very easy to use and street tune. from looking through the non freeware rom editors, most of the "extra" features wouldn't benefit me unless i "tuned" for a living. if i were to switch to obd1, crome free would be my first choice. although neptune would be a close second.
for beginners, diy tuning can seem fairly overwhelming. however with some carefull research, effiecient use of your editor, and patience it's possible to develop your own maps.
Hybrid88
Return to Modification Garage
Users browsing this forum: Google [Bot] and 2 guests
