Does anyone know if I can install a seatbelt harness on my 1990 CRX because apparently you cant because the seatbelts arent located on the pillars but im sure someone out there must know what to do
I understand why you wouldn't want just a harness bar for HPDE, but I don't see why not for the street?Mista Bone said:Harness bar is OK for autox mounted belts, but not to use the bar mounted belts on the street or for a HPDE.
It's because you're held securely to the seat, and have less ability to avoid the roof in a rollover.lukeblood said:I don't get why a harness is a bad idea without rollover protection.
I wouldn't recommend a cage, but a roll bar. A full cage (halo and A-pillar bars) isn't safe on the street either. A roll bar is a main hoop behind the seats that extends above your head, and this is what you need for harnesses in a street car.Willyboy said:So point being a seatbelt harness bar isnt recommended because of safety issues which is why its better to go with the whole cage instead...
Willyboy said:Anyone have any suggestions on what could be done inside then that wont involve any safety issues lol
nihkon said:If you're just looking to change things up in the interior, how about changing out the steering wheel? Or maybe the seats? Those can be done for much cheaper.
More likely for the bolt in kit to punch through the floor on a rollover....like the Mustang did.jfrolang said:It would have to be a monumental collision for the roll bar to move more than a couple inches, seriously.
Better that the roll bar punch through and dissipate stress than for you to have...Mista Bone said:More likely for the bolt in kit to punch through the floor on a rollover....like the Mustang did.jfrolang said:It would have to be a monumental collision for the roll bar to move more than a couple inches, seriously.
Yup. And as the seat back folds backward it comes to rest against the lower bar that forms the belt attach point it creates a chute that directs the crown of your head directly at the top bar of the roll bar. If 10 or 15 MPH impact is enough to bend the seat back then 25 to 30 MPH rear impact would probably kill any taller driver (or passenger) and that's an impact that would normally be considered survivable.Mista Bone said:In that heavy to a rear end collision I'd be more worried about the seat back bending or failing rather than the bar moving.
5-10 mph rear impact is enough to bend the seatback, I know mine did last Thursday night.
