What did you do to your crx today?
Re: What did you do to your crx today?
Postby AZCRXSI » Wed Jul 31, 2019 11:48 pm
tommy wrote:Final version of everything - received the rotor hats back from Static Coatings on LI today.
Going on vacation tomorrow, so will get them installed, the timing fixed, and the car all wrapped up when I come back from the OBX in a week. Should be ready just in time for N26! :tongueblue:
Looks good! :-)b
Nice timing if you can make it.
1990 CRX Si BUILD THREAD
AZCRXSI
Postby Robb » Sun Aug 11, 2019 12:21 pm
Cleaned air filter and throttle body.
Used brake cleaner and a rag for the throttle body.
had to adjust idle a bit after the cleaning as there was much oily gunk removed on the top area of the plate !
Robb
Postby AttackCRX » Fri Sep 13, 2019 6:47 am
Replaced the RTA's with Hardrace hardened rubber, and also the compensator arms with PCI spherical bearing arms. Both upgrades should have been done years ago. Now I just have to finish my alignment since everything fought coming out....
1991 HF - '97 B18C1
1989 Si - gone
AttackCRX
Postby AZCRXSI » Tue Sep 24, 2019 10:26 am
Nothing too big.
Checked fluids and checked tire pressure. Cleaned him up and took him for a stroll.
Its raining in AZ now so he watches from the garage.
AZCRXSI
Postby AZCRXSI » Thu Oct 03, 2019 5:12 pm
Drove him to work today. Nice day out today, cruising with the windows down in 74-deg weather. :-)b
AZCRXSI
Postby tommy » Fri Oct 04, 2019 8:12 am
Buying stuff to get the car back up and running. Found oem wiring and battery tray to put a normal sized battery back to the stock position. Tired of draining batteries in the rear of the car, and want to just eliminate any possibility of issues. Anyone know what bolts the battery tray uses? Looks like the normal 10mm bolts, but not sure.
Will be fun to crawl over the hatch, through the Autometer 4pt rollbar, and finally get to unlock the door. Also thinking about putting normal door handles back on, instead of the rear sedan handles, for this very reason. :idea:
Then I can drive it for a week, and put it back in the garage for winter safekeeping. :sleepy:
Not Forgotten
Postby AttackCRX » Fri Apr 24, 2020 2:24 pm
Sadly enough, Tommy was the last one to post in this thread.
Replaced the rear bumper support, been due for years and also the horn up front. Also cleaned up the spare tire well and started addressing some of the surface rust spots with fresh paint. Will soon be removing the rear interior as it's terribly faded and beat.
1991 HF - '97 B18C1
1989 Si - gone
AttackCRX
Postby Oscar95 » Thu May 28, 2020 6:30 am
Today I changed the oil. I also plan to wash and wax my car
Oscar95
Postby AttackCRX » Thu May 28, 2020 6:51 am
Installed Redshift Competition Coilovers and a DC Sports solid rear strut bar. Removed rear interior and washed the 29 years worth of dirt and grime from under it.
1991 HF - '97 B18C1
1989 Si - gone
AttackCRX
Postby AttackCRX » Sat Jun 06, 2020 9:50 am
Replaced stock front LCA's with Hardrace versions. Tightened all sub-frame bolts.
1991 HF - '97 B18C1
1989 Si - gone
AttackCRX
Postby shorty_boy » Wed Aug 05, 2020 6:50 am
I power washed the moss off the hood. She looks so sad. So much for working on her this summer, but now that the home improvement is done, I hope to at least crank the engine before the end of this month.
1989 CRX HF "... and i will call her betsie and betsie will be mine!"
Resurrected 1/15/2012.
Shorty's Mods, Swaps, and Reviews.
shorty_boy
Postby AttackCRX » Sat Aug 15, 2020 6:57 am
Installed a 92-00 civic dual-core radiator, slim fan and appropriate fan shroud from Go-Autoworks. Gotta keep those temps down on the track! Also got a random thumbs up from a guy in a bone stock EG sedan. 8)
1991 HF - '97 B18C1
1989 Si - gone
AttackCRX
Postby AZCRXSI » Sat Aug 29, 2020 7:36 pm
Sunroof switch died. First stage was intermittently working. Then it moved into flat out dead. Im not working and you no longer get a sunroof. Thank you and good night.
So I was lucky enough to find another unit out of Germany. Switch was in better condition than the current switch and works flawlessly. Sunroof is functioning perfectly. It is nice to have back for sure.
Timing belt and front main seal need to be done in the near future.
After that, will need to start looking for all of the necessary pieces of the next odyssey.
AZCRXSI
Postby Robb » Sat Aug 29, 2020 7:37 pm
Got some JDM Bass tubes :)
Robb
Postby AZCRXSI » Sun Aug 30, 2020 7:11 pm
Cleaned up the CRX today while I had some time.
AZCRXSI
Postby AttackCRX » Mon Oct 05, 2020 8:48 am
Installed Yonaka Motorsports exhaust, wasn't my first choice but there is nothing else available. Literally waited 6 months for a Tanabe Medallion that was on back-order.
Also finished installing an ASR 24mm rear sway bar and subframe brace and exhaust fits perfect around it. Also, Yonaka also fixed that damn muffler slant posted in all the CRX preview pics. That would have drove me nuts.
1991 HF - '97 B18C1
1989 Si - gone
AttackCRX
Postby GregoryFontaine » Mon Oct 19, 2020 5:53 am
georget346 wrote:I am always interested in hearing about what people have been doing to there cars so I thought I would make this post. Everyone follow along with posting what you did to your crx.
To Start it off: nothing big
I put my valve cover back on after having it off the replace the spark plug gaskets.
Took him out for a stroll while shopping this weekend. Neat to see the attention he still gets.
GregoryFontaine
Postby nylumiro24 » Sat Nov 07, 2020 8:33 pm
Washed it, detailed it. And parked it. Image
Sent from my SM-G965U using Tapatalk
nylumiro24
El Chapulín
Postby Angry » Wed Mar 10, 2021 10:15 pm
Patted its fender after walking past it in the drive way.
Also, the battery did this.
No more trickle chargers for me...and this wasn't a cheap one.
Blade Silver 88 Si....Buried in the garage.
I like my woman just how I like my roads.... Curvy!
Angry
Postby AttackCRX » Thu Mar 11, 2021 8:51 am
Installed a Skunk2 70mm throttle body, kinda a pain getting the thing to idle properly afterwards.
Installed a new RaceEqiup 5-point harness, Corbeau harness was out of certification.
Replaced the old front UCA bushings for HardRace hardened rubber variants.
Getting ready for this year's HPDE events!
1991 HF - '97 B18C1
1989 Si - gone
AttackCRX
Postby Robb » Thu Mar 11, 2021 10:21 pm
Angry wrote:Patted its fender after walking past it in the drive way.
I never use trickle chargers.... just diconnect bettery for long term storage
Robb
Postby shorty_boy » Tue Mar 30, 2021 6:22 am
Wow. I need to go check the trickle charger on the TL. Wish me luck.
shorty_boy
Postby Ti Rider II » Thu Apr 08, 2021 11:36 am
I’ve just about collected everything I need for a suspension rebuild/rear disc brake conversion. I finally tracked down a complete ‘90 CRX Si rear trailing arm set (with the next to impossible to find E brake cables). So far I’ve gotten Hardrace RTA bushings, Skunk2 front and rear control arms with hard rubber bushings, a ‘90 Civic EX master cylinder, Goodridge SS brakes lines for discs, Hardrace radius rod bushings, and a few misc. bushings/pieces. I’m still debating whether I want to rebuild the rear brake calipers or just buy new. I’m also eyeing Fastbrakes big brake kit for the front with the Wilwood 4 piston calipers......
Ti Rider II
Postby shorty_boy » Fri Apr 09, 2021 1:59 am
Ti,
I just got my last few pieces to do the same thing. Using EX Master Cylinder, EX Hub for EX's bigger brakes, and EX axles to upgrade from the puny HF axles. I hope to have it all done this summer. I need my baby back on the road.
shorty_boy
Postby peterr991 » Wed Jun 23, 2021 5:59 am
um I mounted my new BOV Sard R2D2
peterr991
Previous
Return to The Lounge
Users browsing this forum: No registered users and 15 guests
