Page 2 of 2
Re: cr-x exclusive
PostPosted: Sat Oct 03, 2020 11:49 pm
by audmcrx
Oscar95 wrote:It promises to be another great project :)
Thank you, I am hoping so
It has been a while so I thought I would post a quick update
The seats are still waiting to be done, ive been told the wait list is huge and because ive got so much else to do with the car im not really in any rush so its no big deal at the moment
I did get a few things done though, namely the timing belt, water pump and tensioner
As usual I was lazy with taking photos because I just wanted the job done
The crank bolt almost killed me but after I decided to say screw it and buy the proper impact it was no trouble
And a nice new sticker for the cam cover
I noticed a small crack on the right side tail light too
That was taken care of pretty quick, you can only see it from a very specific angle but once I knew it was there it annoyed me
The seat belt guild for the drivers side was all discoloured, im not too sure what caused it but I replaced that too
I also began working on restoring my new set of cf-48 wheels
They arent very aggressive in terms of specs and a lot of people think they look weird but I am a big fan
This set is turning out much better than my last ones as ive learnt a few tricks to make the process go quicker and yield much better results
Instead of just sanding them back completely I decided to use paint stripper and a lot of patience to apply it only to the polished lip sections. Once the clear coat was off, sanding the corrosion away took seconds instead of hours.
Then it was just a matter of making the grain uniform and hitting it with some buffing compound and then polish
Here is a photo of the kind of corrosion I have been removing
I also bought some tyres for them
I have been taking the car out as much as I can, it is a lot of fun to drive, it recently rolled over 62,000 on the odometer which means in the year and a bit ive owned it I have driven about 800km
Unfortunately there is an issue with the steering rack so it will have to come out again at some point soon so I can send it away to be rebuilt completely
I have also bought a set of coilovers as the shocks/springs I have in the car, whilst nice, arent as stiff as I would like. They should arrive in the next couple of weeks and ill be able to put the wheels on and have it realigned.
Re: cr-x exclusive
PostPosted: Mon Oct 05, 2020 4:44 am
by signalpuke
Can you please attach your pictures to the forum so that they resize. They are HUGE.
Re: cr-x exclusive
PostPosted: Wed Oct 07, 2020 6:04 am
by audmcrx
signalpuke wrote:Can you please attach your pictures to the forum so that they resize. They are HUGE.
I am sorry, I have resized everything in the thread and cut the majority down to under 300kb
When I looked at the thread everything would auto-resize for me so I guess I never noticed it
I have finished my the restoration on my wheels and am hoping to get the tyres mounted tomorrow
Re: cr-x exclusive
PostPosted: Wed Oct 07, 2020 12:23 pm
by signalpuke
Those wheels look great! Very nice having the caps and covers too, that is super rare. What spec are they?
Re: cr-x exclusive
PostPosted: Fri Oct 09, 2020 5:11 am
by audmcrx
signalpuke wrote:Those wheels look great! Very nice having the caps and covers too, that is super rare. What spec are they?
Thank you, it took me a bit of time to piece together the full set in the condition its in but id say it was worth it
They are 14x6 +38
The height looks crazy but its just stock, it will be adjusted a little when I get the new suspension
Re: cr-x exclusive
PostPosted: Sun Oct 18, 2020 10:15 am
by 91torinoredcrx
Gotta hit them moldings and rockers with some trim paint. Glossy everything is UNACCEPTABLE especially for an Exclusive CRX..
Sent from my iPhone using Tapatalk
Re: cr-x exclusive
PostPosted: Fri Nov 20, 2020 5:44 am
by audmcrx
91torinoredcrx wrote:Gotta hit them moldings and rockers with some trim paint.
I have thought about it but because I will be painting the car down the line I have been hesitant as I have plans to take care of it all at that point, im just waiting for a final part to arrive from japan
My coilovers arrived and I got them installed
They are MCA pro comforts, which are Australian built meaning warranty and support is all in country, and at the moment thats a pretty big plus not having to send things overseas
They dont drop the car very far, but they make the ride a fair bit stiffer and it really feels like im riding on rails now
During the first test drive I didnt scrape on anything which was my main concern, so the height will likely stay at this
You can compare it to the picture posted above with the aero discs, I tried to get the same angle
The car as it sits now
The next job is getting the steering rack back out and doing a full rebuild on it
The seats are finally moving too, I have looked through just about every swatch book trimmers have on hand and couldnt find anything that was close enough to the original camel tan so I have sent a patch away to be custom matched. It will likely take until early next year to get the samples back but I should in the end have it perfect (plus a heap of spare leather for future fixes)
Re: cr-x exclusive
PostPosted: Fri Nov 27, 2020 12:22 am
by audmcrx
Just a quick post about the leather to repair the seats
I have put in for the leather order so hopefully work will start on them within 2 weeks
Re: cr-x exclusive
PostPosted: Wed Feb 24, 2021 5:46 am
by audmcrx
A couple of things have happened since the last post
I was given this cover for Christmas, its great
Another great item from JDS
Today I got the seats back from the trimmer
After all the time spent preparing everything I think its paid off
Before and now
Unfortunately its been very wet here recently so I cant get better pictures until it clears up
Ive got a rebuilt steering rack waiting now too, but I forgot to order new tie rod lock washers so its all waiting on those
Re: cr-x exclusive
PostPosted: Wed Feb 24, 2021 1:27 pm
by bambbrose
The seats look excellent! Great work keeping this rare and special car in top notch condition!
Re: cr-x exclusive
PostPosted: Thu Mar 11, 2021 7:34 am
by Krix
Quality work! It's looking much better
Re: cr-x exclusive
PostPosted: Thu Mar 11, 2021 10:24 pm
by Robb
nice work !
Re: cr-x exclusive
PostPosted: Sun May 09, 2021 10:17 pm
by audmcrx
bambbrose wrote:The seats look excellent! Great work keeping this rare and special car in top notch condition!
Krix wrote:Quality work! It's looking much better
Robb wrote:nice work !
Thank you, I am very happy with how the seats have turned out
With a bit of product they have darkened down a little as you can see on the right
The big job this time was getting the steering rack I had rebuild into the car, its not very enjoyable but I got it done
Old one out, along with a leaky line
New one in
New lock washers too
I also replaced the front sway bar because I had one that was in nicer shape
I did some small stuff at the rear too, like new exhaust hangers to recenter the tips on the bar
The rear bar screws were all replaced with bolts at some point so I got the proper hardware and put it all back to how it should be
Unfortunately the new rack is very stiff, at first I assumed the guy who rebuilt it just tightened the adjuster all the way but it doesnt change at all no matter how lose I make it
When I got the car realigned I spoke to the mechanic and asked him to take a peek to see if he could see anything and it was suggested that the pump was failing, I have sourced a new (used, to be rebuilt) one and i will throw that in to see if it makes any difference
If not I will need to speak to the guy who did the rack and get him to fix it
Which means pulling it out of the car again, im not happy about that idea in the slightest
So if anyone has any idea im all ears
I did some testing with some body parts ive been piecing together over the past few years but none of that will be final for at least another year or two as I need more money to start the next stage of the car
How the car sits now
