Snarflebits 89 HF Rebuild / Swap
Postby snarflebits » Sun Mar 18, 2012 8:43 pm
Hold on to your knickers! I did it. I bought a complete D16z6 from an old Del Sol Si off craigslist. The engine is seized up and I'm going to start to disassemble the beast over the next few days.
The Engine was originally mounted to an automatic transmission so, I'll be looking for an Si manual transmission or possible a DX.
This is my very first attempt at engine building / rebuilding / diagnosing. The engine may be FUBAR'ed but I won't know that until I'm elbow deep in engine grease.
Wish me luck, I'll be updating this thread as there is progress.
"I do one thing at a time. I do it well, then I move on" - Al Baty
"Make your own luck" - Rob Dyrdek
My Build Thread
snarflebits
Re: Snarflebits 89 HF Rebuild / Swap
Postby Corksil » Sun Mar 18, 2012 9:40 pm
Wow look at that baby. It does look like a very complete motor.
As soon as you find a transmission you will be almost complete!
Did you get an ECU or anything else with the swap?
This should be fun, do you have any future plans or mods?
I'm guessing you just want to get the motor running in the CRX before you start thinking too far down the road.
JRSC B20v Build
Hondas I have owned and loved.
CC1 | CD2 | DB2 | DB7 | ED3 | ED8 | ED9 | EE2 | EE3 | EG2 | EH4 | EH6 | EJ6 | EM2 | RA1 | RA4 | RA8
Is your post helpful? Do you have anything constructive to share? Think. Thanks!
My people are working for me. Watch and learn.
Corksil
Postby snarflebits » Mon Mar 19, 2012 8:34 am
Yep, there's a transmission on craigslist right now for 75.00 The guy says it's a CRX si 5 spd , but I'd need to confirm what year.
I didn't get the ECU but I did get the wiring harness that connects all of the sensors.
Oh man, I've got a million ideas and mod's I'd like to do. But I've got to figure out this "new" engine and get it running in the rex first. After that it's going to be time to give the car a make over.
My Build Thread
snarflebits
Postby crxvtec91 » Mon Mar 19, 2012 12:46 pm
Make sure then trans is a B000. If it says A000 stay away!
My build thread: https://www.crxcommunity.com/viewtopic.php?f=2&t=16812
500hp and 450ft/lbs @30psi
crxvtec91
Postby jlicrx » Mon Mar 19, 2012 2:01 pm
crxvtec91 wrote:Make sure then trans is a B000. If it says A000 stay away!
those would be the numbers for the 92-up hydraulic clutch transmission - 88-91 Si transmission would be PL3/3000
or PL3/9000
ZCspeed Racing
jlicrx
Postby crxvtec91 » Mon Mar 19, 2012 2:08 pm
or PL3/9000
If I recall right I have had a few cable trans that said B000
crxvtec91
Postby jlicrx » Mon Mar 19, 2012 4:27 pm
crxvtec91 wrote:If I recall right I have had a few cable trans that said B000
i have never seen a B000 - as far as i know, all 88-91 DX/LX/HF/4-speeds say PL3/A000 - EX and ZC are also PL3/3000 or PL3/9000 - small bearing cases are A000 and big bearing cases are 3000 or 9000
ZCspeed Racing
jlicrx
Postby snarflebits » Mon Mar 19, 2012 7:03 pm
Thanks guys, I'll be sure to look at the markings on any transmission I look at. I think I want an Si transmission from a crx but if you have any suggestions I'd be open to them.
My Build Thread
snarflebits
Postby snarflebits » Mon Mar 19, 2012 7:06 pm
Update Time!
Today i disassembled the engine. And here's how it went.
I started by taking off everything that is bolted to the head and block
It looks like the valves might have some funky build up.But I haven't gotten to the head yet.
I'm new to engines but I fairly certain this may be a new one.
Yep, those are acorns.... Some sad squirrel is missing his nuts.
I got the head off and this was what I saw
I think someone treated their engine like crap
And now for the "fun" part
Yep, that's no good!
Can you say AAAAAAHHHHHHH!
Okay, now one last picture
There is a chip at the bottom of the cylinder wall near the crank shaft.
Here's a close up:
So, what do you think? How hosed am I? Do you think the block will be useable with that chip? Also, there's more of that metal shard molded to the crankshaft. I'm hoping a machine shop will be able to remove it.
That's all I can do today. I'm going to relax.
My Build Thread
snarflebits
Postby vtecn8ive » Mon Mar 19, 2012 8:40 pm
Never buy a seized engine unless it is next to free. You're about to sink a lot of money into that motor.
Take it to a shop and have them assess the damage for you. May need to just have some stuff reground, but most likely will need some extra work. $$
LS ENVY wrote:I like Pen15
vtecn8ive
Postby snarflebits » Tue Mar 20, 2012 7:17 am
Lesson learned right :-)b I just got so excited about finding a motor.
It may not be a total loss. Plus I did get the alternator and Distributor, If the head is good then It'll only be a little financial indiscretion.
But that waits to be seen.
My Build Thread
snarflebits
Postby crxvtec91 » Tue Mar 20, 2012 8:11 am
Head needs a rebuild, nothing crazy. That block needs another crank and maybe a oil pump plus new rods.
crxvtec91
Postby Tian90crx » Tue Mar 20, 2012 11:30 am
^^ true that... the chip will be fine.. you can actually notch that part of the block and be fine.. you have to do it when you use some aftermarket rods..
i have 4 good z6 rods and 3 pistons if you need them.. i'll give them to u for dirt cheap...
Crank you can actually use it from another engine if you can't find another z6.. ( i forgot which ones exactly , maybe the y engines)
tip: you can actually go the junkyards by my house and you i've seen some civics ex, that bring z6.. for the whole engine they will charge you $50... take the crank from there.. :-)b
Aftermarket Quality Turbo, Suspension, interior parts FOR SALE https://crxcommunity.com/viewtopic.php?f=8&t=156674
Tian90crx
Postby snarflebits » Tue Mar 20, 2012 2:00 pm
^^ CrxVtec91 - I may be tackling the head tonight, I need to get it apart to see what the valves look like. I've read a little about aftermarket oil pumps, most people are recommending OEM vs. aftermarket.
^ Tian90crx - That's comforting, I'd like to think that the whole block isn't shot.
Dang, $50.00 for an Engine! I've been doing something wrong!
I'll have to check out some junk yards then. And see who's selling what.
I think the Rods are fine, none of them appear to be bent. I'll post a picture when I get home. But if they're toast and I can't score a $50.00 engine then I'll need to know what "dirt cheap" is :) Plus, it'd be fun to meet you in person.
My Build Thread
snarflebits
Postby crxvtec91 » Tue Mar 20, 2012 2:12 pm
I rather use a oem oil pump even if it is used. Just check and make sure it is with in spec.
crxvtec91
Postby snarflebits » Tue Mar 20, 2012 3:29 pm
I found this handy spreadsheet with Transmission ratio's and notes...
http://www.knology.net/jediklc/gearratiosdseries.htm
My Build Thread
snarflebits
Postby snarflebits » Tue Mar 20, 2012 9:14 pm
I think three of the Rods are still good.The exception should be the one on the right, it was the one that was seized. The parts will be dropped off at the machine shop this Friday.
My Build Thread
snarflebits
Postby Tian90crx » Tue Mar 20, 2012 10:24 pm
When I tore apart my z6 it was so rusted inside that I broke a piston trying to tap it lol .. it wildnt slide out.. I hammered that thing till it broke the piston skirt.. It looks like those rod bolts were hit hard enough to POP them out of the rods lol
Sent from i.d.s
Tian90crx
Postby Corksil » Tue Mar 20, 2012 10:31 pm
wow you sure snarfled up those bits.
I paid 1200 for a b20z2 shortblock with no head and a disgusting crank inside.
for what it's worth I spun a bearing, snapped a rod, and the piston glided to a halt in the cylinder and did NOT damage the head. The motor ran commpletely out of oil and siezed, and the head was fine. I think your head should clean up alright.
50usd for an engine :evil: and no shipping costs wtf i would build ten motors and install the one with the best compression and leakdown pressures if they were that cheap..
it's lookin good, sometimes trial and error is the only way to get to success.
have a machine shop tell you what's up with the crank and block, and get a second opinion from another shop if you want to be double safe.
my machine shop told me that my head needed a line bore and i should mail it off... i cleaned it up and i'm still driving it 10k later.
looks good!
JRSC B20v Build
Corksil
Postby Tian90crx » Wed Mar 21, 2012 12:28 am
Corksil wrote:wow you sure snarfled up those bits.
:lol: :lol:
Tian90crx
Postby snarflebits » Wed Mar 21, 2012 10:11 am
Tian90crx wrote:When I tore apart my z6 it was so rusted inside that I broke a piston trying to tap it lol .. it wildnt slide out.. I hammered that thing till it broke the piston skirt.. It looks like those rod bolts were hit hard enough to POP them out of the rods lol
I'm not gonna lie, I did use a BFH and a pry bar to "carefully" knock two of these out.
Classic!
Corksil wrote:it's lookin good, sometimes trial and error is the only way to get to success.
looks good!
Thanks, Corksil. Tian90crx pointed me to a local machine shop. They were extremely nice on the phone and the reviews they have on google say they're top notch.
My Build Thread
snarflebits
Postby Corksil » Wed Mar 21, 2012 10:40 pm
we are all curious to hear what the verdict on the head, crank and block are.
when the machine shop takes a look post up what they said.
JRSC B20v Build
Corksil
Postby snarflebits » Thu Mar 22, 2012 9:21 am
You got it! You guys will be the first to know.
My Build Thread
snarflebits
Postby snarflebits » Fri Mar 23, 2012 4:58 pm
Dropped the crank, block and head off at the Machine Shop today at lunch. The guy said they are really busy so, I may not hear from him until the end of next week.
My Build Thread
snarflebits
Postby snarflebits » Wed Apr 18, 2012 3:53 pm
I'm still waiting on the machine shop to get back with me. Me and Tian have our blocks at the same shop and they're taking their sweet time.
So, I decided to play around with the HF and mess with timing. I think it is a bit off.
While I was letting it warm up I noticed a loud hissing sound. It was coming from here:
Here's a link to a video of me plugging the hole with my finger.
http://youtu.be/XBSYQ3pr7sI
Does anyone know where that hose is supposed to go? If you have any ideas or links I could read through that would be great. I can't seem to find a diagram that says's that "T" is supposed to be there.
My Build Thread
snarflebits
Users browsing this forum: Google [Bot] and 15 guests
