My 91 crx
My 91 crx
Postby Yucks91crx » Mon May 07, 2018 9:50 am
Hello everybody my name is Luis I'm new to this form I bought a CRX not too long ago it was running perfectly fine when I bought it it has a hundred and sixty five thousand miles on it to 91 CRX stock engine the only modifications I've done to it or intake on a PGM fi I recently started having this problem where it wouldn't idle past 3000 RPMs any time that it would go over 3,000 RPMs it would stutter like rev limiter it shifts into every gear fine but none of the gears will go past 3000 RPMs any thoughts
Yucks91crx
Users browsing this forum: No registered users and 17 guests
