Finding 2 coil spring insulator bushings
Postby street_legal_gokart » Wed Jun 27, 2018 9:56 am
While installing new front struts, I found that my CRX is missing the front spring mounting bushings (FSM calls it a "spring mounting rubber") and instead had some rubber hose wrapped around the top of the spring as a "bushing". Looks like the original part is discontinued, and I can't seem to find an aftermarket replacement.
Has anyone found a source for this part or a part from a compatible car?
Also, the KONI struts I installed have the perch set for stock ride height, yet they dropped the front .25". I'm guessing this is because of the lack of this bushing since it looks fairly thick. Any ideas?
Link to discontinued part:
https://www.hondapartsnow.com/genuine/h ... 3-014.html
1991 Si
street_legal_gokart
Users browsing this forum: No registered users and 9 guests
