Starts once then studders
Postby mingus847 » Thu May 21, 2020 6:11 pm
I put a rebuilt D16A6 in my 91 CRX si. After resetting the timing belt it fired right up, but it sounded
like an old V8 with solid lifters. I adjusted the valves to .007 intake and .008 exhaust. After readjusting the timing belt it started right up again, but when I turn it off it won't start. Any suggestions would be appreciated.
Thanks
1991 Black CRx Si
mingus847
Users browsing this forum: Google [Bot] and 16 guests
