86 CRX SI not starting
Postby Katra180 » Fri Sep 09, 2016 12:58 pm
Just bought a 86 Crx SI standard transmission that was running fine at the time except for a bad battery. I replaced the battery and the car worked fine for a couple of days. With the new battery I was able to start the car a couple of days but then one day I drove it to work. Started just fine no hesitation, able to drive it to lunch, but when I tried to drive home it wouldn't start. Didn't make a single noise. Dashboard lights, head lights, raido, ect all work perfectly. Was able to push start it. Luckily was on a ramp in a parking garage so just pushed it back enough to run it down the ramp and pop it into second. Ran fine, drove the entire way home with no problem. Which amounts to an hour commute in heavy traffic. Still won't start, only way to get it running is to push start. Jump start does not work
Things I have done and tested;
Replaced starter and ignition switch
Make sure there was good connections on the battery and starter for power and ignition
tested with a multimeter
power is getting to the starter
ignition switch is getting the "start" signal
Voltage drop test was fine
Battery is charged
Looked for blown fuses
Right now I'm a bit puzzled. Anyone have any ideas what it could be?
Katra180
Re: 86 CRX SI not starting
Postby Sandell » Mon Sep 12, 2016 12:23 am
Try checking voltage to your tps?
Sandell
Postby cheveeCRX » Wed Apr 11, 2018 6:41 pm
Any update on this topic?
I bought a ‘86 Si and drove it 1000 miles home. The next day, my daughter snubbed it out and now it won’t start. It has battery power, starter signal, etc. just no crank. It push started to pull up to the garage and there it sits.
I’m going to replace the starter and see what happens.
cheveeCRX
Postby cheveeCRX » Mon Apr 23, 2018 4:09 pm
$25 junkyard starter and a couple hours later - VROOM!
I removed the battery and tray to get better access, but it was probably not required.
On to the next repair...
cheveeCRX
Return to 1st Generation CRX
