1st Gen(84-87) Crx FAQ's
Re: 1st Gen(84-87) Crx FAQ's
Postby asianflava » Thu Aug 29, 2013 10:19 am
No you can't, unless you want to put a lot of time and work into it.
Since this is a FAQ, maybe it should be posted that the 1st gen (84-87) and 2nd gen (88-91) are totally different cars. They only share the same name, and nothing else. Asking if ANYTHING will interchange is the same as asking if parts from a Prelude will work.
91 CRX Si (hers)
89 Civic Si (his)
01 Toyota Highlander (hers)
07 Toyota Tundra (his)
asianflava
Postby Baker » Sun Sep 01, 2013 9:29 am
asianflava wrote:Since this is a FAQ, maybe it should be posted that the 1st gen (84-87) and 2nd gen (88-91) are totally different cars.
Done and highlighted.
:-)b
Postby ksousa » Tue Sep 03, 2013 4:11 am
Actually, there is one relatively significant item that can be swapped between the two generations of crx. The seats! Direct swap.
Check out my build!
viewtopic.php?f=10&t=40861
ksousa
Postby Baker » Tue Sep 03, 2013 3:49 pm
ksousa wrote:Actually, there is one relatively significant item that can be swapped between the two generations of crx. The seats! Direct swap.
:umno:
2nd gen seats don't even interchange and swap within the generation.
Postby jfrolang » Wed Sep 04, 2013 11:11 pm
The seats from a 2nd gen with pillar-mounted seat belts will swap into a 1st gen.
jfrolang
Site Admin
Postby ksousa » Wed Sep 04, 2013 11:57 pm
:umno:
I know, thats why I thought it was worth mentioning that the two generations of crx share the same seat pan bolt pattern/locations. And both have seats that are designed to be closer to the floor than the regular civic, so you wont mess up your sitting position like if you swapped to non crx honda seats.
Check out my build!
ksousa
Postby Baker » Thu Sep 05, 2013 3:39 pm
ksousa wrote:
:umno:
They don't share the same seat bolt pattern.
Seats from 89-91 Crx with door mounted belts, will NOT bolt up and fit.
Previous
Return to 1st Generation CRX
