Transmissions noise
Transmissions noise
Postby ki11r0y1086 » Sat Apr 04, 2020 9:30 pm
I have a 95 JDM GSR trans with a factory LSD in a 91 CRX. I have new motor mounts, suspension, brakes, bushings, bearings, tie rod ends, and other goodies. When i release the clutch in any gear i hear a thunk, its more noticeable in 1st, 2nd, and reverse. With the car in neural while coasting I hit the brakes and don't hear a noise, when in gear I hit the brakes a slight thunk. My first thought was suspension or bushings but they are all new and installed correctly. I then checked for clearance around the motor (B20) and any where it might be hitting. I have yet to find anything. While the car is on jack stands I am having a friend put it in 1st/revers and pull the clutch out. I will be looking at the motor to see if it is hitting any where then do the same test on the ground. When the car is on jack stands I can rotate one wheel roughly 10 degrees before the other side starts to spin. I also hear a loud clack noise from the trans once the other side starts to rotate. This seems to me it is the diff. Before I take the trans out to rebuild it is their any other test I can do? or any other ideas? If it is the diff can I rebuild it? If I need to buy a new diff can I use an LS with an aftermarket LSD? I know the bolt pattern is different but if i replace the whole unit will it work in the trans? Thank you for your help and stay safe during this crazy time.
ki11r0y1086
Return to Modification Garage
Users browsing this forum: No registered users and 19 guests
