transaxle, fender, door glass, sway bar, hatch hinges, more
All parts relating to the CRX. If it's from another Honda, but is commonly used for the CRX, it's ok.
Postby Honduh » Sat Aug 01, 2020 9:48 am
1990 HF Transaxle
Mileage unknown. Pulled from a car that had a timing belt failure. $250. Located in Tucson. Shipping extra. Contact me if shipping is required.
OEM Driver Side Fender in Honda Flat Black Primer
Still have the receipt from a Honda dealer - purchased for a 90 HF. Not sure what years this fits. This fender has been installed and spent about 2 years on my car in Tucson - therefore no rust issues. Black factory primer has been rubbed thin from car washing/drying. No dents, stored in a garage on hooks away from risk of damage. Driver (left) side. $250 delivered with a tracking number.
Passenger Side Door Glass for 90 and 91
One minor blemish along top edge. Photos can be shared - contact me. Located in Tucson. $160 including shipping with a tracking number.
There is a small amount of grey primer overspray on the glass.
Powder Painted Rear Sway Bar from 90 Si
Includes 6 steel brackets. Everything has been sandblasted and powder painted in satin black. New OEM rubber bushings have been installed at each end of the sway bar. Never installed after painting. Located in Tucson. $80 shipped with tracking number.
Rear Hatch Hinges
These were soaked in engine oil for a couple months to free up the hinges and are now stored in a toolbox. Compatible with a 90 CRX and probably 88 - 91 but I cannot confirm this. Comes with original flanged nuts. $30 shipped. Located in Tucson.
Variety of OEM Crank and Connecting Rod Bearings
Color coded by Honda for a precise fit. Some of these bearings are unobtainable through Honda as they have been discontinued for years. These are all bagged so I'm not exactly sure what I have. Some original packaging has been opened as some bearing were temporarily installed and Plastigaged many years ago during an engine build. If you're building a CRX engine I might have the bearings you need. Located in Tucson.
90 Si Front Brake Calipers - Rebuilt and Unused
Caliper frames not included. Clean, not rusty. Located in Tucson. $80 shipped. no brake pads included
Honduh
Return to Parts - For Sale or Trade (FS or FT)
cron
