the people's republic of racing (based in the people's republic of berkeley, ca) present to you: the franken-rex!
it's been a long time since i posted here, but we just got most of the bugs ironed out of the full racecar build and have been taking it to small track days in CA. it's an enduro car, so simplicity, reliability, economy and driveability are key. at the same time, it is made out of about 8 different civics, crxs and integras... which is what you do.
you should see the spreadsheet. it's epic.
the chassis is an 88 HF, with 98 integ rear arms, 91 si front suspension, some pci sphericals here and there but mostly poly bushings. a set of craigslist koni yellows w/450lb springs in the front, and 600lb in the rear. (we have a set of 800lb springs if we feel stiffer is better). no sway bars.
engine is a driveway rebuild early 88 d15b2 w/mpfi upgrade, and we have an 89 Si transmission. the shift linkage is all poly/aluminum with a single-bend steel short shifter. we 'upgraded' to an Si fuel tank and get almost a full gallon more gas... after two hours of flogging flat-out at a track day last weekend, we burned through 10g. this is perfect for enduro -- we want the car on track for at least two hours between driver changes and minimize time in the pits.
inside: full cage, fire suppression, custom seat/slider mount (driver height ranges from 4'12" to 6'3"), oil pressure gauge, kirkey seat, schroth harnesses.
it's slow, handles like a dream and you never need the brakes! we'll be painting the car soon, and getting the aero sorted (front splitter, rear spoiler).
the only work we farmed out was for machine work on the head/block, transmission rebuild, and cage welding. we built the cage bits under the direction of john pagel @ evil genius racing in his shop, and he welded it in to the car. the cage is some seriously amazing work, and i have incredible amounts of headroom at 6'3".
if anyone has questions about the car, build, etc, lemme know! i got a bunch of Qs answered here, and this board has been a nice, drama-free source of reliable advice and i'm down to give back.
