I have to give the credit to Jmart for the project, I just made a pretty write up for it. Here's the .pdf file for it, here are the other write ups. I'll post the text here, but there are pictures and stuff in the .pdf.
Rear Sway Bar Installation into a non-Si CRX
First off I want to credit JMart for this project. I personally have only had Si models, but he converted a Rio Pink 89 DX to a 90-91 Si, swapping everything but the roof over from his wrecked Si.
So why do you do this? The best upgrade for any front-wheel-drive understeering Honda is a rear sway bar, whether you're adding it or upgrading the stock one. Unfortunately, Honda decided not to include a factory rear sway bar on the non-Si (HF and DX) model CRXs. For some aftermarket bars, you can use the rear tow-hook mounts with an adapter bracket. If you don't want to drop a lot of money on one, or you think an OEM Si sway bar is enough, this is how you can mount it like stock.
Materials and Tools
CRX/Civic Si rear lower control arms
CRX/Civic Si sway bar with brackets
sway bar to lower control arm bolts
sway bar bracket to frame bolts with nuts (use shock top hat nuts)
Grommets to fit the large holes
Electric drill with 3/8" bit and a stepped bit large enough to fit a 14mm socket through
14mm socket x2 and ratchet x2 with extension
jack and stands
Removing the old LCAs
This first part is pretty easy, you need to take out the stock lower control arms. Unbolt them from the hub, the shock, and finally from the car, and pull them out.
Installing the Sway Bar
All CRXs have the holes for the bracket bolts in the frame, but they don't all have the welded-on nuts for the bolts to thread into. A good choice for these is some shock tower (top hat) nuts. These nuts also make good replacements for the nuts that are welded to the frame to hold the lower control arms.
First thing, before you start drilling, empty the trunk of carpet and anything else that could be damaged. Using your 3/8" bit, drill through the floor pan from the bottom. Now you have four holes in the trunk that look directly down to the ground through the frame of your car. Get back inside the trunk, and open each hole up with your larger stepped bit.
You can now drop the nuts down through the top holes, while feeding the bolts up from the bottom. Bolt the brackets up to the car, letting the sway bar end links hang free for now. After installation, use the grommets you got to plug the holes.
Holes in the trunk for the bracket bolts.
Sway bar bracket installed (bottom view), just like OEM
Re-Installing the LCAs
Before you get them in, this is a good time to install new OEM or polyurethane bushings into your LCAs. If you already have some, this might be a good time to grease them up so they won't squeak as much. If you're installing used OEM arms, you may want to clean them up first, at the very least chase all the threads with a tap.
Put the inside end in first, and bolt the arm to the frame of the car. Then swing it up and bolt it up to the hub. Now bolt the sway bar end link to the LCA. Note that the first side will be much easier. To avoid stripping the hole or breaking anything, try to use a jack on the bar or the wheel to line up the bolt as much as possible, and remember to use anti-seize on all suspension parts.
Bolting the LCA to the shock and sway bar...
...and to the hub
